That is not a IH pump reading the label on the ID plate will help, but the odds are that there are no parts available from a manufacturer. M&W is one such company, and might be the manufacturer. Taking it apart will identify the seal type and if it has a number it will probably cross over to Chicago Rawhide, or National seal numbers. Motion Industries can help. It might have a worn groove in the shaft. If so it needs to have the new seal placed to not run in that groove or it will leak again. A product called Speedy Sleeve can repair the groove for a good seal. It will come as a Kit for the OD and ID of the seal. If it is an Oring seal (possible) and the shaft is grooved, it might require machining to allow the speedy sleeve to be used, and the housing to fit around it with a deeper Oring groove. Best of luck, and let us know how things work out. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
