Re: E-4A Mag Question
Posted by Nebraska Kirk on August 29, 2012 at 20:49:23 from (207.91.4.159):
In Reply to: E-4A Mag Question posted by old on August 27, 2012 at 19:12:27:
The factory spark safety gap is a LOT wider than .030, it is at LEAST .250" Take the cap off the mag and you can look inside and see how far the point of the screw is from the collector ring.
You do not adjust the screw, as I said in my previous post: "turn the screw in tight, that is all you have to do."
