Re: Farmall M distributer problems
Posted by wayne in mn on August 29, 2012 at 20:58:24 from (66.188.166.241):
In Reply to: Re: Farmall M distributer problems posted by nick roepke on August 29, 2012 at 18:43:38:
Lacquer thinner or brake cleaner works well. With the points closed and switch on, pry the points open with a screwdriver and let them snap shut a few times. You should see a spark (low voltage) at the points and with the coil wire near a ground there should be a nice blue high voltage spark!
