Re: what Fluids for 354 rear end?
Posted by Steve Wilkens on August 30, 2012 at 01:04:31 from (67.177.151.72):
In Reply to: what Fluids for 354 rear end? posted by Steve Wilkens on August 29, 2012 at 00:14:13:
Thank you so much for the reply. Now...How much? I can't find a listing for the capacities of this tractor. Does the transmission and differential share a common case? If they don't share the same case...where in the world do you put it in. I have looked the case over, and currently have the lift housing off, so pouring in gear lube is easy. The only plug I can find is on top of the transmission, that is why I wondered if they share the same case. Thanks, Steve
