J hooks. Now that I look things over, I have a block from a 1945 tractor based on the serial number but the rest of the tractor may be a 1942. The casting code on the side of the torque tube is 8638 DL. L would mean 1942 right? I'll have to look at other parts on the rear end to see what the codes end with to be sure.
The blocks may have been swapped and the small fuel tank discarded.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
