Re: 560 Diesel won't start
Posted by charlieu on August 30, 2012 at 05:03:11 from (206.53.193.95):
In Reply to: 560 Diesel won't start posted by Nisse on August 29, 2012 at 18:22:19:
After reading your post, I think that your glow plugs are not working. You said that you checked for power to the glow plugs. Did you check if the plugs are heating? The service manual tells how to use the glow plug meter on the dash to check each plug. You can also use an ohm meter and check each plug with wires disconnected. Some people just remove the plugs and check to see if they get hot when electric power is applied. Let us know what you find. charlie
