Re: Farmall A Wheel Weights
Posted by El Toro on August 30, 2012 at 06:00:20 from (108.3.143.30):
In Reply to: Farmall A Wheel Weights posted by bordermen on August 30, 2012 at 04:55:08:
third party image
I think I used 5/8 carriage bolts for the rear weights and I couldn't find any long enough so I
had short pieces of allthread welded to the carriage bolts. The square shoulder on the carriage bolt should fit the square hole in the rim to keep the bolt from turning when tightening the nuts. Fastenal may have them.
This was back in 1975 when I restored a Farmall A. I had the weights shot blasted at work to remove any rust. I used an epoxy primer on the weights and over the nuts on the carriage bolts.
Hal
