Re: Engine speed for a sickle bar mower
Posted by mkirsch on August 30, 2012 at 06:46:45 from (64.80.110.75):
In Reply to: Engine speed for a sickle bar mower posted by DaveLamp on August 29, 2012 at 18:00:35:
These pitman mowers shake a lot, and you may find that running at full throttle causes the mower to shake the whole tractor. Slow down.
Feel it out. If you find the mower plugging a lot try running at a higher RPM in a lower gear.
With my Cub, I run 2nd gear at a about 5/8 throttle. Much faster and the harmonics build and practically shake you off the seat.
