Re: 2 cyl wisc engine on Model 66 baler
Posted by El Toro on August 30, 2012 at 07:39:15 from (108.3.143.30):
In Reply to: 2 cyl wisc engine on Model 66 baler posted by Va Gasman on August 29, 2012 at 18:15:03:
I would squirt some engine oil around those valves if you can get to them when it's not being used. Pour some oil down each cylinder then rotate the engine one revolution. Then pour a little more and reinstall the sparkplugs. Hal
