Re: 2 cyl wisc engine on Model 66 baler
Posted by JRSutton on August 30, 2012 at 09:59:23 from (75.130.109.233):
In Reply to: 2 cyl wisc engine on Model 66 baler posted by Va Gasman on August 29, 2012 at 18:15:03:
There's a little valve cover plate on the side of the cylinder (behind the carb) - actually one plate for each cylinder.
Take the appropriate one off (peel off all the old cork gasket and blast it out with compressed air)
Use a light crow bar in the valve spring to gently move the valve. It'll just pop back into place.
rotate the engine a few times to make sure it doesn't stick again - it'll probably be fine after that.
