Re: 450 fan- can it truly be...
Posted by Hugh McKinney on August 30, 2012 at 10:12:58 from (99.195.66.81):
In Reply to: 450 fan- can it truly be... posted by P and R Pete on August 29, 2012 at 18:45:17:
One way that you can be pretty sure to get the pulley halves to completely separate (and thus get the belt off), is to loosen one of the fan bolts, (there are four), and wrap some baling wire around it, then tighten it back up. The other end of the baling wire, you attach to one of the frame rails or other stationary object. Next, with the set screw loosened, use a hammer and hard piece of wood, like an old hammer or ax handle, to strike the raised lugs on the sheeve. By hitting the hard wood, and not hitting the sheeve directly, you provide a cushion that protects the sheeve from breaking. It worked for me.
