Re: Engine speed for a sickle bar mower
Posted by MNGB on August 30, 2012 at 10:35:20 from (67.230.224.205):
In Reply to: Engine speed for a sickle bar mower posted by JRSutton on August 30, 2012 at 10:04:29:
Hi I have a IH model 22 mounted on my Earthmaster and per the manual the sickle should run at 1700 cycles or 850 RPM's on the pitman wheel, I think most tractor PTO rpm's hit 540 before full throttle. I found with the Earthmaqster/22 mower that about 3/4 throttle and 2nd gear works very good as posted I started out in 1st gear but found the a spped od 2nd made for better cutting, here again a lot depends on mower condition mine has a very good sickle and the guards and ledger plated are like new how every it does shake.
GB in MN
