If the clutch alignment tool is used, it is just [placed in the spline hole and into the pilot bearing. I then release the clutch (three bolts) untill I can just move the disk with the alignment tool a tiny amount in any direction withoput it falling. I then move the disk left and right and up and down till I believe i have it centered perfectly using the tool. I then take out the bolts, and put them where they belong. Now you are assured that the disk is centered. leave the tractor in Neutral, and turn on the PTO as you put the engine in have someone rotate the PTO with a Pipe wrench to rotate the clutch shaft till the splines engage. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
