Posted by Owen Aaland on August 30, 2012 at 16:26:01 from (216.47.35.72):
In Reply to: 560 Diesel won't start posted by Adrian Billheimer on August 29, 2012 at 18:22:19:
A good flow of fuel from the tank on the return line only indicates that the return check valve is missing from the bottom of the tank and that the line is clear.
What you need to check is that you have a flow of fuel coming from the return fitting on the top of the pump while the engine is cranking. Your description of almost starting one time and then nothing is what you could expect if you had a plugged return fitting on the pump.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
