Re: Tillage Implement
Posted by mkirsch on August 31, 2012 at 05:06:40 from (64.80.110.75):
In Reply to: Tillage Implement posted by greebas on August 30, 2012 at 20:34:45:
No offense erik, but something like that will barely scratch the surface of unworked ground, and you'll bend the heck out of the tines trying.
A 130 should be able to pull one actual chisel plow tine.
I would try to find a salvage yard that's scrapping an old chisel plow. Get 2 tines (one for a spare) and a piece of the toolbar. You can get new fast hitch points from Agri Supply online for a lot less than used ones on ebay.
After that all you need is some steel to tie it all together, and a welder.
