Re: H tranny seal replacement
Posted by Zachary Hoyt on August 31, 2012 at 15:48:58 from (184.12.70.98):
In Reply to: H tranny seal replacement posted by Senator on August 31, 2012 at 14:52:14:
You would have to remove the belly pump drive shaft to change the countershaft seal and I think you would have to remove the pump in order to have room to remove the transmission input shaft to get at the seal up there. It is not hard to remove the pump, you just need a floor jack or two friends (a floor jack is usually easier).
Zach
