Posted by Haas on August 31, 2012 at 16:10:31 from (75.252.40.130):
In Reply to: Re: MD Mag is Dead posted by IAtractorKid on August 31, 2012 at 14:29:10:
There should be a pointer and mark (notch) on the pulley on the front of the engine. Line those up and note where the rotor is pointing and then take the mag off. When you put it back, make sure the rotor on the mag is pointing the same direction as when you took it off and you should be good to go. If your crank thing is stuck, you can turn the engine by using the belt pulley flange. Put the transmission in neutral and the pulley in gear. Put a couple of bolts in the flange and use a bar to turn the pulley flange and thus the engine. Just be sure there is no possibility the engine can start when you do this!! If you take the plugs out and put the start lever in gas position, it will be easy to turn the engine with this method.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
