Re: H tranny seal replacement
Posted by Ol' Gimpy on August 31, 2012 at 16:41:05 from (74.67.127.235):
In Reply to: H tranny seal replacement posted by Senator on August 31, 2012 at 14:52:14:
Might as well just go ahead and drop that Lift-All unit,a like the guys said,replace the Lift-All shaft seal while you"re at it.You may want to check closely the input flange and bottom bearing retainer/Lift-All drive shaft for a worn groove,and have a "Speedi-Sleeve" at the ready for each.With the new seals so small and made thin,you may want to even "Double" the seals up.Be careful handling that Lift-All unit!!
