Re: MD Mag is Dead
Posted by gene bender on August 31, 2012 at 17:03:05 from (67.55.226.88):
In Reply to: Re: MD Mag is Dead posted by IAtractorKid on August 31, 2012 at 14:29:10:
Yes thats the way i do them if they are setting on fire position the rotor will snap when you remove then be hard to put back in. Just remember where the rotor is pointed then you can re-install with rotor in same position and be fine. When installing you can be correct or 180 out. Been doing them that way for many yrs.
