Re: Farmall Super H Head.
Posted by D Slater on August 31, 2012 at 18:39:14 from (184.15.7.159):
In Reply to: Re: Farmall Super H Head. posted by New2supers on August 31, 2012 at 18:18:41:
With flat top pistons about any H head will work if the correct length valves for the head are used. To have about the same power use a cast # 8043DC gasoline head if you don't find a SH 8043DD head. 300 and 350 heads work but all won't have the opening for a vent suction line in the head casting rear. They used a vent line out of the valve cover. No problem to get the valve cover with the head and use PVC hose from it to air cleaner inlet pipe.
