Re: Fighting with my Zenith
Posted by gene bender on September 01, 2012 at 04:38:00 from (207.177.56.236):
In Reply to: Fighting with my Zenith posted by kopeck on August 31, 2012 at 19:14:02:
Just because you can blow air thru doesent mean the passage is completely clean. On the main body you mite need to use proper size drill bit and by hand. I use a seperate small drill chuck to use small bits to clean the idle circut hol in the bottom of the main body start with a verry small and go a little larger by steps and usually will find rusty stuff on the tip of the bit then by blowing and using a mag lite i can see lite looking down the main discharge jet hole. float setting doesent seem to be your problem. I haveseveral of these carbs on the A and B,BNs that i have even have some extra carbs
