Re: MD Mag is Dead
Posted by El Toro on September 01, 2012 at 06:39:25 from (108.3.143.30):
In Reply to: MD Mag is Dead posted by IAtractorKid on August 31, 2012 at 11:18:11:
Rub those points with 320 wet or dry until they're shiny then see if you have fire. Is the impulse coupling snapping? You can pull the mag
by bringing No1 piston to TDC on the compression stroke as been suggested or note where your rotor is pointing on the cap and make a sketch. THEN DON'T MOVE THE ENGINE after the mag's removed. When the mag is returned rotate the rotor to the spot shown in your sketch and reinstall the mag. Also note how the plug wires are installed on the cap so they're in the correct firing order. Hal
