Ya if doing that yes it can be a bit of a problem. A couple things to try. #1 take a propane torch do not light it and wave it around the carb and the manifold to see if you have a vacuum leak which will cause odd problems. #2 pull the idle screw all the way out and see if it will still idle. If it does then the idle circuit is clogged up and needs to be opened which you maybe able to do with spray carb cleaner and air
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
