Posted by jimb2 on September 01, 2012 at 09:53:10 from (99.241.38.122):
In Reply to: pto engaged posted by carlsandberg on September 01, 2012 at 07:08:38:
Hi, common problem on 74 series tractors, especially if they are not kept undercover. The moisture gets in the lever actuating mechanism. Use your favorite penetrating oil and lube everything while moving the pto lever back and forth. Also there is a rubber boot on top of the MCV valve that you may have to lift and spray oil on the pto actuating valve.
All the above only applies if no one has attempted to adjust the pto lever or there is no obstruction has fallen down in behind the seat or the sheet metal on the right side has not been bent.
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
