Re: 300 starter relay update
Posted by Zachary Hoyt on September 01, 2012 at 10:43:19 from (184.12.70.98):
In Reply to: Re: 300 starter relay update posted by John T on September 01, 2012 at 09:13:20:
The wire on the small I terminal goes to the coil side of the voltage resistor. I checked it with a meter and found that even when the ignition switch was off there was still 12 volts at the I terminal. I disconnected the wire from the I terminal and now it shuts off when I turn the switch off.
Zach
