Posted by ChShaffer on September 01, 2012 at 19:38:25 from (96.247.159.123):
In Reply to: 656 hydro cont'd posted by ChShaffer on September 01, 2012 at 15:51:40:
Pete 23 you are correct in that the large tube (suction tube) is still firmly fastened. Could not shake it. Apparently what ever holds it in place is further forward in the tractor as I could not see any bracket or holding device. The small steel tube had the end bent shut and several holes chewed in it from the gears in the tractor rearend. I am guessing the ring gear as it was the closest in proximity. Cleaned out the shaving and metal fragments as best we could. Will change the filter and add new oil when re-assembled. Thanks for the rational on the placement of the small tube. Certainly want to minimize cavitation.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
