Re: Fighting with my Zenith
Posted by Janicholson on September 01, 2012 at 19:46:17 from (96.24.99.126):
In Reply to: Re: Fighting with my Zenith posted by kopeck on September 01, 2012 at 19:00:07:
Lower the float level (toward the ground) so there is less fuel in the carb. Seriously, the float level is set to make it run correctly, not set correctly to make it run. Easy change and might be a miracle. Jim
