Re: 300 starter relay update
Posted by Janicholson on September 01, 2012 at 20:01:16 from (96.24.99.126):
In Reply to: Re: 300 starter relay update posted by Zachary Hoyt on September 01, 2012 at 13:34:40:
Use another 4 amp diode. Place it in the wire going to the coil side of the resistor. Attach it so the band end is toward the coil. Attach the other end to that S terminal. Now the starter switching voltage will be the bypass supply. The diode prevents the ignition voltage from energizing the S terminal. Jim
