Posted by Owen Aaland on September 01, 2012 at 22:20:16 from (216.47.32.144):
In Reply to: 856 injector drive posted by Bradiniowa on September 01, 2012 at 20:44:54:
If you did not wire the throttle lever on the pump in the full throttle position it is possible that the governor weights have fallen out of place. Looking in the end of the pump you should see all six weights in place with the two slots on the thrust tube mating into the tabs on the governor arm. If they are out of place you can usually get them back into position with a long screwdriver.
When assembling the pump back on the drive shaft make sure the dimple on end of the slot in the pump mates with the dimple on the drive lug of the shaft.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
