Re: piston rings c123
Posted by NoNewParts on September 02, 2012 at 04:54:28 from (67.240.145.25):
In Reply to: piston rings c123 posted by LaDuke Farmall on September 01, 2012 at 10:51:37:
with so many years gone by,
only choice is to take it apart first and
see what you have, then order.
could be anything in there.
if you are just re-ringing-honing
and new bearing shells, pull them all.
many I've taken apart had different piston styles-ring count
in different holes
if you have them out,
bore, number of rings 3-4, each ring/ring groove thickness,
and whether you want to run a chrome or cast iron top ring if both available.
