Re: 350 diesel timing
Posted by Janicholson on September 02, 2012 at 07:45:50 from (96.24.99.126):
In Reply to: 350 diesel timing posted by farmall guy12 on September 02, 2012 at 06:21:07:
White smoke that is diesel fuel means cylinders are not firing. Running very rough. If it was running for 5 minutes and didn't clear up, things that can be wrong are from stuck valves to low compression or bad injectors. Not diagnosable from the description given.
If it is antifreeze, it will smell sweet, and the enging might run fairly well. The coolant will however disappear. Jim
