Re: H tranny seal replacement
Posted by pete 23 on September 02, 2012 at 10:58:11 from (74.32.238.2):
In Reply to: H tranny seal replacement posted by Senator on August 31, 2012 at 14:52:14:
Myself, I would not even consider replacing the seal with out pulling the whole input housing,(those six bolts). I have seen too many screwed up jobs putting that coupler back on. Some do come off easy, some not. Then the half moon key works it way out when you can't tell what is happening and ruins the coupling, and still leaks anyway. You will be glad you pulled the input shaft as you will surely find something else wrong. Loose or worn ball input shaft bearings, Pilot bearing shot, bolt holding pilot bearing is loose. Something else for sure. You need to remove belt pulley attachment or the plate to put it back together to support shaft into pilot bearing.
