Re: H tranny seal replacement
Posted by Stemmy on September 02, 2012 at 13:05:22 from (174.252.122.138):
In Reply to: H tranny seal replacement posted by FBH44 on September 01, 2012 at 06:04:51:
Yes be very careful with those. When I took mine out I cleaned them up and put a small coat of grease on the bolts and the rubber grommets. Prevents them some seizing in the coupler and keeps the grommets from drying out.
