Re: Farmall M Inner Axle Carrier Gasket
Posted by Rootsy on September 02, 2012 at 13:35:41 from (174.232.66.25):
In Reply to: Farmall M Inner Axle Carrier Gasket posted by jimb2 on September 01, 2012 at 17:21:08:
The gasket seals two rings. The first around the axle housing pilot and the second around the OD. If you separate it you need to drain the oil down as the drain back is between the two sealing rings. Not sure how far it will separate as i have never done it that way. To take it all of the way off is a bit more involved.
