Re: M W/shepard diesel conversion
Posted by Lmack on September 02, 2012 at 14:04:17 from (24.131.58.167):
In Reply to: Re: M W/shepard diesel conversion posted by Red Dave on September 02, 2012 at 06:42:28:
Gasoline engines run with lower compression and lower internal stresses in rods, crank shaft, and cylinder walls. Unless the engine was designed with the intent of handling stresses anticipated in a diesel it will not hold up (witness the MF 35 four cylinder diesel of the early 60's that were factory made from converted gasoline 4 cylinder engines). The reason we do not see many of those conversions was because they created more problems than they solved for a working tractor.
