Re: Selective lever controls for belly pump
Posted by DeltaRed on September 02, 2012 at 15:45:45 from (67.6.225.104):
In Reply to: Selective lever controls for belly pump posted by Patrick HMD on September 02, 2012 at 15:11:10:
That is a selective valve to run the front and
back cultivators sepatetly.Left slot runs the
rear,right slot runs the front,center slot runs
both.It only works with a oneway cylinder.Leave it
on!It is something unusual most folks have never
seen.learn how to use it.If you just HAVE to
remove it,someone out there will want
it!Garanteed!No,you cannotrun the belly pump with
no oil.fill it with oil,pull the handle,see if it
squalls/loads the engine.remember,the clutch must
be out as it driven by the transmission,not the
engine.
