Posted by John T on September 03, 2012 at 06:47:31 from (216.249.82.117):
In Reply to: 6V gen to 12V posted by bkpigs on September 03, 2012 at 06:26:58:
I have successfully used a 6 volt genny to charge a 12 volt battery by just using a 12 volt Voltage Regulator NOW DONT ANYONE HAVE A CALF Im NOT saying thats engineering correct and Im NOT saying it charged at any real high rate, Im ONLY SAYING it worked. Theres a chance the 6 volt field coils may draw too much current and overheat but mine never had a problem.... A genny dont necessarily know its output, that depends on how fast it spins and how much field current is pumped through it i.e. the job of a VR or manual Low/High charge controller.
The CORRECT thing to do is have a genny shop change out the fields and anything else necessary.
NOTE if changing from a Cutout Relay to a full fledged Voltage Regulator on a 3 brush genny, one could adjust the third brush to max charge or else just do away with it and convert to a standard 2 brush unit. The VR if correctly matched to the genny will regulate and limit the field current so theres no need for the old 3 brush system and a low/high charge control.
NOTE it makes a difference of course if the Genny is a Class A (JD, IHC, Oliver etc.) or Class B (Some Fords and Masseys) as each require the correct Voltage Regulator
It may be cheaper n easier just to buy a new or used already 12 volt genny and VR and be done with it.
Got any old fashion mom n pop genny starter alternator shops nearby??? Try Kenneth at Classic Generator in Texas
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
