Re: H trans seal and countershaft seal
Posted by Haas on September 03, 2012 at 16:39:48 from (75.200.9.152):
In Reply to: H trans seal and countershaft seal posted by j hakenwerth on September 02, 2012 at 19:19:10:
NAPA can likely cross any of the three IH numbers you have. Folks below have given you the numbers. But...next time just take all three of the numbers to NAPA and they will cross the seals for you and get the correct seal. (That is if you have a NAPA guy that cares. Some are better than others!) The new seal won't be like the original, as the seals have changed and are much better now than the originals. Some say that you should use two of the new thinner seals in place of the old style thick seals. I've always used just one and never had a problem as long as the shafts that the seals run on are in good condition. If the shaft is not in good condition, use a speedi sleeve or have the shaft resurfaced. The speedi sleeve is more expensive than a seal, but likely much cheaper than a new part. Most likely the reason for the multiple numbers you came up with is that IH changes the seal type to a newer version or they get them from a different supplier. Likely any of the numbers you found would fit the application.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
