Re: H vs 300 noise level when running
Posted by Zachary Hoyt on September 03, 2012 at 18:28:43 from (184.12.70.98):
In Reply to: Re: H vs 300 noise level when running posted by Janicholson on September 03, 2012 at 16:09:56:
Thanks, that makes a lot of sense. I put the wiring on the relay back so it matched the diagram you posted, except that I disconnected the wire from the I terminal. I will follow your recommendation about the diode if I seem to need it to start in the cold, but at least for now it seems to be starting fine without it.
Zach
