Clean the screen at the carb inlet fitting. Clean the screen in the sediment bowl. use a wire and clean the tank to sediment bowl connection. Use a very non sparking (LED) light to look into the tank to see if it has dramatic rust issues. If it does, it will need to be cleaned by a Radiator (usually) shop, and coated with a tank sealer. The issue will then go away. If the tank looks clean, all will be well just cleaning the parts. Do not put an inline filter in it. It just wastes money and adds to issues. The existing system is great if clean. Jim
Today's Featured Article - New Hitches For Your Old Tractor - by Chris Pratt. For this article, we are going to make the irrational and unlikely assumption that you purchased an older tractor that is in tip top shape and needs no immediate repairs other than an oil change and a good bath. To the newcomer planning to restore the machine, this means you have everything you need for the moment (something to sit in the shop and just look at for awhile while you read the books). To the newcomer that wants to get out and use the machine for field work, you may have already hit a major roadblock. That is the dreaded "proprietary hitch". With the exception of the
... [Read Article]
Latest Ad:
[More Ads]
