Farmall Fast Hitch Disc
Posted by Dean Olson on September 03, 2012 at 20:55:47 from (98.196.66.64):
third party image
third party image
third party image
I bought this disc just outside St Louis MO when I was at the RPRU. Finally
got chance to use it and it works perfect. It's 8 1/2' and my 300 will pull
it in 4th with no problem. It is heavy and even with all the weight in front
it's makes the front end light when up.
It has one disc that is about an inch smaller in diameter than the rest,
pictured. I suspect that it must be a replacement.
However do they/would it wear that way?
Any body know what model this disc harrow is?
Is the draw bar welded to the back center original or farmerized to pull a drag?
