Re: %$#@ viton-tipped needle won't stop leaking
Posted by wayne in mn on September 04, 2012 at 05:48:49 from (66.188.166.241):
In Reply to: %$#@ viton-tipped needle won't stop leaking posted by mkirsch on September 04, 2012 at 05:37:57:
Try sanding the edges of the needle so it doesn't hang up on the side of the seat.
Is the float rubbing the side of the float bowl?
