Re: Super A Stuck
Posted by another thought on October 12, 2000 at 02:56:37 from (209.254.185.18):
In Reply to: Super A Stuck posted by David (Ala) on October 11, 2000 at 21:32:09:
David: Push the clutch all the way in and block it so any problem with the tranny\rearend etc is not involved with starting the engine.. harvey
Post A Followup
: Re: Re: Super A Stuck
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
