Re: Belt pully gearbox. Is it a simple drop in?
Posted by Janicholson on September 04, 2012 at 17:51:53 from (96.24.99.126):
In Reply to: Belt pully gearbox. Is it a simple drop in? posted by Patrick HMD on September 04, 2012 at 16:19:27:
The mesh of the drive with the trans gear can be set with gasket thickness, but unless it has none, and the gears bind, no one (that I know of) measures it. I would put a stout rubber band on each bolt to hold it up out of the center two holes so they do not snag on the parts while sliding it into place. Then remove to tighten. Jim
