Re: Super A Stuck
Posted by Larry on October 12, 2000 at 04:16:31 from (205.171.70.150):
In Reply to: Super A Stuck posted by David (Ala) on October 11, 2000 at 21:32:09:
I think you may be on the right track...STARTER. I've got a Super C that will do that once in a great while, you'll try to start it, and the starter will hang up, and lock the engine. I simply back the starter bolts out a little, and shake the starter and everything is fine. This tractor has only done it twice...weird when it happens. I agree with the other guys, I wouldn't pull it, you could really foul up something doing that. Lets us know what you find out.
Post A Followup
: Re: Re: Super A Stuck
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
