Re: 986 digital tach
Posted by TJV on September 04, 2012 at 19:11:40 from (67.230.241.17):
In Reply to: 986 digital tach posted by HossW on September 04, 2012 at 11:52:08:
it gets power from a switch activated by oil pressure (looks alot like the pressure sender for a gauge but has two wires) it is located at the rear of the engine on the right side behind the oil filters. I have had trouble with these. You can get a replacement from napa for about 1/3 of what case charges and they are probably made the ithe same chineese factory. but it could also be just the wire connections on this switch
