Re: Paint color for belt drive and starter
Posted by mkirsch on September 05, 2012 at 05:28:13 from (64.80.110.74):
In Reply to: Paint color for belt drive and starter posted by Rod51M on September 04, 2012 at 09:13:15:
The pulley is not wood. It is PAPER!
IMHO leave it alone. If you start sanding it down you peel off the protective coating that has been formed over the years from having the belt dressing burnished into the surface as the tractor ran the ensilage cutter, or buzz saw. You'll never recreate that.
The pulley's surface is pretty much impervious to moisture right now. Exposing fresh paper will let it soak up anything in the vicinity, and it will be garbage in short order.
Unless the pulley is really nasty and ragged on the outside, leave it alone.
