Re: farmall super C hydraulics???
Posted by mkirsch on September 05, 2012 at 05:31:42 from (64.80.110.74):
In Reply to: farmall super C hydraulics??? posted by vanceheller on September 04, 2012 at 20:25:16:
It's either one of two things:
1. You lost the prime on your hydraulic pump. It should come back if you cycle the hydraulics several times with the fill plug removed. If that doesn't work, pressurize the block through the fill hole with an air compressor.
2. You put it back together incorrectly. How, I don't know. Could be the too-thick o-ring. Could be you put something else in turned 90 degrees, or flipped over, or, or, or...
