Farmall Tractors Discussion Board
Re: IH 86 series shift problems
Posted by RickB. on January 12, 1999 at 17:47:43:
In Reply to: IH 86 series shift problems posted by todd u on January 12, 1999 at 17:08:37:
How about the dump valve on the TA? If I remember correctly, It should bottom out on the snapring when the clutch is engaged, and the spool is pulled out of the housing when the clutch is pressed, which shifts the TA into low, allowing easier shifting. Verify the correct adjustment of this valve, as I am not absolutely certain, but I know it is a factor. Your trans brake pad could be toast, too, metal on metal doesn't stop too fast.
Post a Followup
: Re: Re: IH 86 series shift problems
