Re: Clutch alignment tool
Posted by rustyfarmall on September 05, 2012 at 14:39:47 from (67.55.162.174):
In Reply to: Clutch alignment tool posted by BigTone on September 05, 2012 at 14:33:29:
Slip the tool through the splines of the new clutch disc, and then insert the small end of the tool into the pilot bearing in the flywheel. Now you are ready to install the pressure plate.
The alignment tool takes the place of the transmission shaft.
